Is there any smilies in N73 Music Edition?:con?
Smilies
Nope, smilies are not supported on S60 - at all.
The closest you can get is the : - )
Which you get (with T9 on) by pressing 1 repeatedly.
I think you are reffering to the sms 2.0 version, u can check at www.sms2.com for further info, also i think it should be supported by your network operator.
sudipt wrote:I think you are reffering to the sms 2.0 version, u can check at www.sms2.com for further info, also i think it should be supported by your network operator.
Not sure thats quite the same thing though - such things should be supported out of the box on the N series (although Windows Mobile doesn't either ...) - its irritating to have gone from various other phones (S40, SE K or W series), and then have the N73 not support such things - especially when the "lower end" Nokias (S40) have supported it for a while.
