Sony Ericsson Bluetooth sterio headset
2 replies · 4,216 views · Started 05 February 2008
....Does not work very well with e51. 😡
When i connect the headset to my e61 it works good, but 9/10 times it will not even "marry" itself with my e51. And if they descide to get along, they soon start to fight again and it all ends in a dissconnect... 😮
They guy in the store said e51 supported sterio BT headsets but....
Anyone seen this? can it be fixed?
/Robspace
I can't help you with that particular headset, but I've not had any problems getting my E51 to work with either a Motorola BT stereo headset, or the Nokia BH-500, so the E51 certainly does support Bluetooth stereo headsets in general.
I also have problems with Jabra BT320s stereo bluetooth headset. While E51 generally recognizes device and pairs successfully, I can't get stereo sound out of it. I've tested that headset with my friend's SE K850i and there it works OK. Any suggestions how to tell E51 to use A2DP profile, instead of general hands-free?
UPDATE: After some time it just started working fine 😮 All I've had to do after pairing, was to switch off and back on Jabra headset...
