N95 8gb connection USB
1 replies · 5,328 views · Started 06 February 2008
I have an N95 8GB and it doesn't connect to the computer when I use the USB cable with it. No options come up on the phone when I connect the USB cable to the phone. I have installed N series PC Suite with connectivity cable driver.
WHATS THE PROBLEM
i had the same problem after i installed a update on the PC suite.
it deleted my drivers and would'nt find them again so i had to reinstall it all after removing it
it was Nokia software updater's update what caused a driver error, then my PC auto removed my drivers to the usb cable and phone.
If u dont know how to manually install the drivers to it, then only solution is reinstalling the PC Suite
