Im sure mine used to be a nokia address now it has changed?
Whats the standard nokia address for assisted GPS that I can enter into the phone?
Liam
Liam
supl.nokia.com
mine is h-slp.mnc010.mcc234.pub.3gppnetwork.org
not a clue where it came from anyone seen this one before?
Ive seen 2 N95 8Gbs come with odd addresses. None of the addresses ever seem to work except the supl.nokia one given earlier.
If you think that address you have might be important, save it somewhere and you can put it back later if need be.
saved on here then
it used to be the nokia one i dunno why it changed on its own
this is mine on nokia 6120 classic
gps server address
h-slp.mnc019.mcc502.pub.3gppnetwork.org
Err, you have that on a 6120 classic? Are you sure?
from Nokia Europe
How do I know if I have A-GPS activated on my device?
Please check following settings from your Nokia device:
Main menu > Tools > Settings > General > Positioning
> Positioning methods - select assisted GPS.
> Positioning server > Access point - Select your service provider's access point.
> Positioning server > Server address - the positioning server address used for A-GPS (default supl.nokia.com)
