Text colour change to themes
2 replies · 2,309 views · Started 08 February 2008
Hi all,
Is this possible to change once its been made into a .sis file.
Seems all the themes i try have black writing, but on something with a bit of a black background and im stuffed when it comes to reading text on the phone txt messages etc.
Had a quick look at Carbide.UI but cant see it giving me the option to open a .sis and make changes.
if im missing something id appreciate the help.
Crispy
In a few instances the problem is in the firmware and nothing you can do in carbide will allow you to swap the text colour sadly. Each firmware update tends to fix these little things, but break other bits.
Carbide is already a tad non-intuitive 😊, Symbian and Nokia aren't really doing a great deal to fix these problems, though it's also prevalent in a lot of other phone types by other manufacturers - I guess they assume everyone will just use the default themes, and they are on their own if they want anything else either fully black or white.
At the moment, nothing can be done.
