install questions
5 replies · 1,734 views · Started 29 January 2003
hello guys i'm new bytheway.
tomorrow is my big big day i get my nokia7650 :P
i have one guestion is it hard to install software for the phone?
or is it something like windows?
hope you guys help me out
Thanks All!
later
Hey Chac(K
Its very simple.....you will need to have a usb connection or bluetooth connection to enable the phone to communicate with the PC.
Then all software can be eaisly installed via the Nokia PC Suite.
Hope this helps!!
:roll:
[quote="Chac(K"]...i have one guestion is it hard to install software for the phone?
or is it something like windows?...[/quote]
I think those are the same thing 😃
Its really easy to install software on Symbian.
Just send the file to phone using BT, IR, email or wap
And a few key presses and its done 😃
thanks for the reply's guys.
but you dont get the Nokia PC Suite with the phone?
or am i wrong
of course you'll get the Nokia pc suite with the phone...
😃 you can install program with the pc suite or directly on the phone :P
you can also connect with infrared... 8) 8) 8)
