Nokia N95 8gb and ngage
1 replies · 1,866 views · Started 09 February 2008
Do you need the latest firmware version on the n95 8gb to install ngage. I have firmware version 10 and when i try to install ngage, it fails near the end of the installation and says installation failed.
manatwork wrote:Do you need the latest firmware version on the n95 8gb to install ngage. I have firmware version 10 and when i try to install ngage, it fails near the end of the installation and says installation failed.
you should have atleast v11 firmware available for you phone i'd update if i was you,your phone will perform much better
