How to transfer files to 7650 (other than .sis, .jad & .
4 replies · 5,716 views · Started 29 January 2003
How do I transfer files from my pc to my phone? (It works just fine the other way around)
An earlier poster wrote this:
1. Locate the "rom" in your PC.
2. Right click it and select "Send to" --> "Bluetooth" --> "xxx", where "xxx" is the BT name of your 7650.
or else:
1. Goto "My Bluetooth Places" --> "Entire Bluetooth Neighborhood", locate your 7650, and you will see a folder named "Public Folder".
Anything you drag-and-drop in this folder, will be send to your 7650 indox.
But this doesn't work for me! I have no "My Bluetooth Places" on my desktop. Can I download it somewhere? I've got a Nokia 7650 phone, and a Bluetooth USB Dongle with XTNDConnect Blue Manager software. But this piece of software doesn't seem to work. The "Send file to" menu is dimmed when I try to transfer!? (The connection and PC Suite works just fine)
Please help!
Regards Kindhyt (Denmark)
Open Bluemanager.
Drag and drop the file that you want to send onto little phone icon in bluemanager.
Well, thanks for the fast reply, but I actually already tried that with no succes 😞
But I found a solution myself! I simply installed some drivers and manage software from this URL: http://www.billionton.com.tw/extra/download.htm
AND IT WORKED! It was a longshot, but hell... Now it worx! I don't know WHY it worx, but it does!?
i use a pocket pc compaq 3970 model to transfer is easy as eating pie
