Basic Question and im sure someone can answer very easily.
Ive a N95 non 8GB, when transferring music from pc to phone using nokia software the music become stupidly fast when I tried to play it on my phone, can someone put me right please ?
i hope this does'nt happen to me i've just converted 5 albums ready to transfer to my phone in the morning and i did'nt keep a back up of the unconverted versions of the albums.
I'll let you know tomorrow if its just you or if it happend to me 2.
1 of the albums are for my girlfriends N95 and the others for my N95 8GB so it'll be easy to find out if it's the phone or music manager whats causing the problem if it does happen
Think youve answered part of the question by saying they need to be converted.....how do you do this ? ta
mattblue wrote:Think youve answered part of the question by saying they need to be converted.....how do you do this ? ta
in the nokia music manager
scan your pc for songs you want to add
select the songs you want to add to your collection,
press FILE top left
PRESS COPY TO MY COLLECTION
it will ask you then if you want to convert when copying
If u said no to convert when copying
tick the songs you want to convert then
select CONVERT TO MOBILE OPTIMISED FORMAT
from FILE top left
you can chose convert format in OPTIONS>settings >conversion
i don't know if this will make a difference as i've had no problems playing unconverted music on my mobile they was all mp3 format
