iSync plugin for OSX 10.5.1 and N95 8GB v1.15?
1 replies · 5,151 views · Started 11 February 2008
Does anyone have iSync working with a N95 8GB using 10.5.1 (Leopard) and N95 8GB with latest firmware (1.15). I have had no joy using the 'official' N95 plug in or the amended plugin that others seem to have got working by amending the plist file...
"What I did to �fix� it was to change the gmi+gmm required in the MetaClasses.plist file (found here: /Library/PhonePlugins/Nokia_N95_8GB_1v1.phoneplugin/Contents/Resources)
Just replace �Nokia+Nokia N95 8GB� with �Nokia+Nokia N00″ and iSync works like a charm."
Except it doesn't work for me! Anyone manage to get it working?
I've only just bought this N95 8GB and I have to say if I can't get it synching with my Mac sharpish it's going on Ebay! I'm finding the device very frustrating at present. It might work beautifully on a PC but it's proving a little fiddly to work with on OSX
Ben Frain wrote:Does anyone have iSync working with a N95 8GB using 10.5.1 (Leopard) and N95 8GB with latest firmware (1.15). I have had no joy using the 'official' N95 plug in or the amended plugin that others seem to have got working by amending the plist file...
I have no problems syncing my N95 8GB with my mac, it works perfectly.
PM me your email and I will send you the iSync plugin I use.
