What do I do if i think i inserted a wrong product code?
5 replies · 3,644 views · Started 11 February 2008
Hey... I got my N95-8GB... loaded up NSS and after changing the product code and reconnecting my phone, my pc no longer detects my phone and the NSS scan for device reports
Checking Framework...Done.
->..pdginterfc.dll version: 1.0.479
->....pdg4fbus.dll version: 1.0.1641
->....pdg4mbus.dll version: 1.0.106
->.....pdg4fls.dll version: 1.0.1164
->....pdg4flsc.dll version: 1.0.0.58
->pdgphonebook.dll version: 1.0.189
->.bb5usbflash.dll version: 1.0.0.42
Reading Virtual USB device...Done.
->Serial: 4E425C, HW: 0.0
Testing Interfaces...
->USB DKU2....Supported.
->USB CA-53...Supported.
Testing Directories...
->DCT4 Loaders Dir('Flash'😉......Found.
-->0 file(s) found.
-->Please copy the loaders first!
->ADSP Loaders Dir('FlashUsb'😉...Found.
-->0 file(s) found.
->DCT3 Loaders Dir('fls1sup'😉....Found.
-->0 file(s) found.
->Products Dir('products'😉.......Not Found.
Trying to do anything gives me an error message... Please help!
travis88 wrote:Hey... I got my N95-8GB... loaded up NSS and after changing the product code and reconnecting my phone, my pc no longer detects my phone and the NSS scan for device reports
Try a hard reset (power on the phone whilst holding 3, * and GREEN buttons). Keep the buttons held down until the Nokia logo and music come on.
If this doesn't work, I assume you cannot reset the code using NSS to the one printed behind the battery compartment?
The phone did not reset when pressing those 3 buttons for quite a period of time... 😞
ok i finally carried out the hard-reset however nothing happened.... i still can't detecct my phone 😞
u need to uninstall the pc suite then reinstall it
then it will check for the drivers and install them to allow connection,
i had to do this the other week after my pc stopped detecting the phone and deleted my drivers.
it worked perfect after i did the above.
p.s it was also after a update
...first thing I always do is panic. Nothing like those sheer moments of terror you feel as your N95 undergoes a brief hiccup that you've not ever experienced before - followed by the sheer elation from having it switch on again and work perfectly.
You tell yourself that you'll never do anything like that again, hug your phone and apologize to it, but you know, a week later and you're trying to figure out how to tweak the swipolicy CRC's yet again 😊
