W960i software help
8 replies · 17,495 views · Started 11 February 2008
Hi all
Received my W960i this morning...
nice phone.
Any info into where I can get some relevant, and useful, software... preferably free?
Thanks in advance
Thank you, Gebbly
The SE is certainly lots more easy than the Nokia.
Thanks for the links, will check'em out.
When downloading an application, what should I select as my application installer?
(currently the Nokia Application Installer is selected as my default)
dont quite follow your question. Most of these apps will be .zips containing .sis files. just save to pc and then transfer the .sis to your phone (via, whatever means...bluetooth maybe)
normally only need a single .sis. is there a readme file that explains? what files are there?
i have downloaded this to my computer and paid for it! when i run programe it says it can not register files and the code
....005f7xbutton.ocx ....comes up,
also when i registered on mobile9 web site it asked me to enter the pin number i have been sent to my email address, i have been sent the pin but cant find where you enter it as i am not getting prompt for it
please help as i have paid for this product and cant use it ,can i get a refund?
...iam using a windows xp computer and w960i mobile
...thank you
Registration / Notice: Action:
Sony Ericsson Media Studio 3.2
Reg.-Code:
7945745912
