I lost my old N95 when I was snowboarding (DOH!) so I took the opportunity and upgraded to an N95 8Gb. I'm on Vodafone and now all of the custom themes from my old phone and new ones I've downloaded give a certificate error when I try to install them.
Has Vodafone somehow locked their themes on there or is it a generic N95 8Gb problem?
8Ball
I had the same problem, but i sorted it out by searching for "Nokia N95 8GB" themes, and this sorted out my problem.
tom1992755 wrote:I had the same problem, but i sorted it out by searching for "Nokia N95 8GB" themes, and this sorted out my problem.
I did that, but they still won't install. I went to www.Zedge.com
Where did you get your themes from?
8Ball
I got mine from that website too.
I had to go to "Application manager, options, settings, software installation and change that to all" after that they worked but i am getting certificate expired recently but thats because there from a year ago.
so you changed your phone date backwards yeah? 😉
That did it. Thanks very much!
