Help with Infrared!
2 replies · 1,082 views · Started 29 January 2003
I'm trying to connect my 7650 to the Computer, from USB Ir, the Ir adapter are coming form Tekram...
But I don't find the phone...and I don't know what to do...anyone have a clue??
Do you have the newest drivers for your motherboard? That can be the problem,if you have usb2 port?
if you are using an ir port which is directly pluged on motherboard
First of all remove all components related to ir device then restart your computer be sure that they are completely removed then turn off. plug the device. then turn on and open bios. from there activate the irda from integrated peripherals (I dont know wheter yours have an option of integrated perripherals I have gigabyte motherboard, you can find it from your board's manufacturer's site). İf there is no option like that, it means you have to update your bios. After enabling irda, windows automatically detect device and install proper drivers. if your device has no tag on it to inform its manufacturer you can install microsoft drivers. after installing it you have to setup an network with ir device. after that install pc suite and select infrared option for communication. your suite will detect your phone (before that windows will 😊 )
