File transfer failing
3 replies · 2,326 views · Started 13 February 2008
Why is this failing / not working on 8gb n95
it sais everytime i plug the usb in your 4 choises so i want to choose data transfer and when i go ok it sais unable to activate data transfer mode , memory is in use by another application.
Then i check and nothing is in use , no blue circles on my apps.
nothing so why.
Do you store your text messages on the memory card? This happened to me and as soon as I changed the storage to phone memory all was ok.
I had a similar problem with n958gb until i removed the shozu application and instead put it onto the phone mem0ry and that helped hence the reason why most sugest putting applications on the phone memory rather than the harddrive
Harddrive?
Harddrive is usually referring to a stationary, or fixed drive inside a device.
Most recommend you install applications to the internal memory (phone memory) rather than the external or removable media.
