Proporta power back-up,problem with 2",50mm
0 replies · 961 views · Started 15 February 2008
Just got the kit (yesterday) from Proporta and it is very complete and makes a good impression as does the company.
I have N82 and want to use the GPS in conjunction with "Nokia Sports Tracker".
Problem: The Proporta adapter plus Nokia connector stick out 2" or 50mm from the side of the phone making it very vulnerable to being broken,bent or snagging.
Solution: Right angled Nokia adapter letting the whole assembly lie along the side of the phone, rather than sticking out.
The end of the Proporta charging common plug is not standard so adapting from another accesory maker does not seem immediately possible.
Anybody with a sugestion or do I have to make the right angled piece myself?
PS, found this at Mobilefun and hopefully it will come as picured and should solve my problem
PS have written to Proporta today so maybe they will come back with solution if so will post here.
PS found this Nokia Retractable USB Charger at Mobilefun as hopefully it will arrive as pictured and should solve my problem. So prob solved
