[FONT="Century Gothic"][FONT="Garamond"][FONT="Franklin Gothic Medium"][FONT="Verdana"]When I drag and drop a video clip onto the phone icon in PC Suite, the video strangely gets added to my phone's memory and not my SanDisc. I only realised this today when I realised that my videos were still on my phone after I took out my memory card. Where can I change this setting?
Secondly, when I drag and drop mp3 files I get an error saying:
'Nokia Launch Application has stopped working.' If I add the mp3s manually to my music folder, the default mp3 player on my phone doesn't see the mp3s. What's wrong?[/FONT][/FONT][/FONT][/FONT]
Hello Grantward,
May i know your PC details and Version of your pc suite? Are you using Nokia PC Suite or NSeries PC suite?.....:con?
The drag and drop feature used to work before.
I'm on V20 for firmware, I have the most recent update of PC Suite and my PC is using Vista Ultimate. PC is a AMDx2 3Ghz.
If you go to settings across the top, then go to the tab with your phone name, you can specify the file path you want to save 'certain file types' to on your N95.
No idea about the second point.
I am also facing similar kind of problem,but my issue is related to video files.Whenever i drag and drop any avi file onto Nokia PC suite,it gives an error that the file cannot be converted.Also 2 or 3 times,I got an error that PC Suite has experienced an exception error and needs to be closed.
Has anybody else faced this kind of problem?I am using Nokia PC Suite 6.85.14.1.Is there any solution for this issue?I desperately need answers for this.
