Is there any software for n73 to be used as a remote control for tv or vcr? thx
remote control for n73
problemer wrote:Is there any software for n73 to be used as a remote control for tv or vcr? thx
I've heard various rumours that the PsiLoc ir remote application was being canned.
Problem is that apart from some success with the Nokia 6600, the IR port is pathetically weak on most of these mobiles, so you've got to be stood right next to the device you're trying to control in order to get it to do anything.
Which is pretty useless really. Just go and buy an all-in-one from the local supermarket.
