slide hang up
6 replies · 8,797 views · Started 18 February 2008
This Is Freeware Application
When You Get Incoming Call Just Slide Up For Answer.
For Ending The Call Just Slide Down.
MUST BE SIGNED.
i have not tested this app can someone test and give reports thanks in advance
Attachments: slidehangup.sis (2 KB)
This has already been posted (unless you are posting a new version)
Some people have reported a few bugs with it, though for me it works fine.
Apps such as these which provide the "end call on flip close" functionality are great. My one moan is that none of them, to my knowledge, differentiate from handset as opposed to headset use.
It would be very handy if the "end call on flip close" feature was temporarily disabled for headset use.
Imagine the following.
Your headset (bluetooth or wired) is connected to your phone. You decide you want to make a call so you get out your N95, open the flip and dial. When the call connects you now want to put your N95 away again and continue the call via headset. But if you close the flip the call is now ended. So either you have to delicately put the N95 away with the flip remaining open or you have to hold the N95 until the call ends.
See my point.
F
you 'used' to be able to close the slide once you had sent the command to dial... and it wouldnt cut off. It would only cut off when the call was ringing...
I dont know if thats still the case??
kontraband wrote:you 'used' to be able to close the slide once you had sent the command to dial... and it wouldnt cut off. It would only cut off when the call was ringing...
My problem with ShutUp is that the only thing I want it to silence is the alarm going off in the morning when the phone is otherwise off. Presumably, the fact the phone is off means ShutUp isn't loaded at that time so doesn't function to silence the alarm. So I don't use that app.
FlipSilent suffered from the "end call on flip close" whenever the flip was closed regardless, as I recall when I last tried.
I may reinstall at some point.
F
