N95-3 Case
0 replies · 2,992 views · Started 18 February 2008
Ok maybe I just don't know where to search, but I'm getting frustrated. Is there a decent case for the n95-3. NOT the 8 gig, NOT the n95-1. The US version! The n95-1 has the right front, but the wrong back. The 8 gig has the right back, but wrong front. I don't want to have to buy two different cases and then Frankenstein them together in order to get a case for some protection. I don't want the InvisiShield either. Also, I would like to be able to just pull my phone out and use it, instead of having to unwrap it or pull it out of the case to use it. All of the "cases" that I can find for the n95-3 require you to remove a flap or something from the front in order to use it. I am a power user and use my phone a lot in a day. The gels look good enough, but I cannot find one that is designed for the n95-3. Does anyone have any suggestions? I tried the search and was unsatisfied with the results. If this has been discussed in detail before, maybe someone can direct me where to go.
On a side note (for you designers out there): Would it be too hard to create a crystal case that housed a lens shutter on the case? A shutter like what the n95-1 had, but on the actual case for some protection for those of us who didn't buy the n95-1. It would be handy for the n95-3 and the n95-8 gig. Just a thought for someone who wanted to make some money.
Thank you in advance and sorry if I sounded like I had an attitude.
-Cheers,
Zumstin
