Rhapsody and Bluetooth
1 replies · 1,723 views · Started 18 February 2008
I use Rhapsody and have synced with a usb cable , selecting media player as the connection type.
When I use bluetooth I can't see how I can set the connection type. As a result I can't sync (Rhapsody is presented with two memory cards , and not a n95 player as with the usb cable).
Any ideas?
Regards,
Y
I'm pretty sure that the M$ PlaysForSure DRM does not allow wireless connection. You have to use a cable. Stoopid I know. On a related note, I sure hate the way Rhapsody has to re-read all the songs on your N95 every time you run it. It can take a real long time if you've got several gigs of music.😡
