Hi, is there any way to hide the ringtones that i added on my phone in the galery? Because when i want to listen my mp3's on the galery i have to skip always the ringtones that i laoded...
Hide ringtones on gallery
Using 3rd part file explorer application change atribute hidden of your ringtone files. Then refresh library.
If i do that.. when i will go on profile setting and change ringtone they will be hidden there too?
You need to set it as the ringtone when it is NOT hidden (and appears in the music library). Then set it hidden and refresh the library. It will still work as a ringtone provided you don't move it.
The same goes for message alerts too.
hidden sound files are visible in the profile settings.
