Changing N95's What do I do?
2 replies · 2,031 views · Started 19 February 2008
Hi all,
Im getitng another N95 and have to back up what I need to do before I change.
Please advise on the following as this is the software I use and any other ideas.
1) Contacts back these up to computer I have none on memory card.
2) Messages take the opertunity to clear memory of old messages.
3) View Ranger I should be able to reinstall using old disk? I guess I export and Import all my POI's? What about tracks and routes?
4) Panoman I will loose this? as It was Phone specific?
5) Google Maps No action required? Just Download again
6) Game 2d Space invaders find and download.
7) Sports tracker where do I find the routes?
8) S-Tris FInd and download,
9) Fr. Bubble find and download,
10) Lightsabre find and download,
11) Sudoku find and download,
12) Modi Reader Find and download,
13) Nokia Maps (I forgot this one hence edit!) what happens will I need to down load them all again?
Any other advise? I will keep my present Memory Card I just plan to swith it between phones. Will doing this cause any problems?
This is not going to be as easy as I first though...
ANy advice on these please let me know, I am sure I am not the first in this predicament...
Gerrit
Contact view ranger about that. Its locked to IMEI, so they will have to activate it for you I think. Also, ask them about the POI etc. They are incrediably helpful.
4 - unsure. Think its fine, but check.
6 - dunno.
7 - dunno.
10 - not sure if lightsaber needs signing. On that note, if you do have anything that needs signing, you'll have to do it again, as you'll obviously have a new IMEI.
13 - shouldnt do.
As for everything else, its just a matter of finding them.
The routes are stored on the memory card in a folder called sportstracker, so you should be fine here, although always best to check.
gerrit wrote:
13) Nokia Maps
Maps should be fine as they're also stored on the memory card.
If you can, keep the old phone for awhile, that way it's easy to get something off if you've missed it.
