Alright, I had the iPhone for like 2 months, then sold it and bought the Nokia N95-1... Now I bought the Nokia N95-3. My question is. Will the data plan have 3G coverage too?:con?
iPhone Data Plan
then sure .. data is better delivered over these high speed connections.
So ask your phone company - or tell us what it is .. someone may be able to help you.
Nice move from the iPhone to the 95-8G .. 😊
MylesG23 wrote:Alright, I had the iPhone for like 2 months, then sold it and bought the Nokia N95-1... Now I bought the Nokia N95-3. My question is. Will the data plan have 3G coverage too?:con?
ok it seems you are on ATT in the US. most of the people on this forum are in the UK. the 15 dollar media max plan is the correct unlimited data plan for the n95-3 on ATT. i use the same phone. then you add your text on top of that if you need a text plan. 15 bucks for unlimited is a great deal! i used up 1.6GB this month already using emTube on my n95-3!
oh i see, you are asking if the iphone plan will give you 3g access. yes. ATT doesnt differentiate between GSM and 3G. if the phone is capable it will lock on to 3G towers regardless of your plan or sim card.
Thank you guys so much for your help!
