hello guys my n70 has been broken for 3 months now if i take it to the technicians, some say its the LCD others say its SOFTWARE. i need help i dont know which software is it that i need for my N70 because if i switch it on it gives light and a blank LCD display it doesnt display the NOKIA logo and if i try to switch it off it wont go off unless i take out the battery. tell me what software i need where to get it or the web address for it. :s::s::s::s: u can reply via my e-mail : [email][email protected][/email] or here
N70 blank screen no images
Without display, you can�t do the upgrade process! So the only way, sure way, is going to a Nokia Service Point.
ndoh wrote:hello guys my n70 has been broken for 3 months now if i take it to the technicians, some say its the LCD others say its SOFTWARE. i need help i dont know which software is it that i need for my N70 because if i switch it on it gives light and a blank LCD display it doesnt display the NOKIA logo and if i try to switch it off it wont go off unless i take out the battery. tell me what software i need where to get it or the web address for it. :s::s::s::s: u can reply via my e-mail : [email][email protected][/email] or here
suggest formatting (last thing before going to care center)
1. remove the battery > put it back
2. press and hold *+3+call > then turn on the phone > wait until "formatting" show on screen
whiskynine wrote:suggest formatting (last thing before going to care center)1. remove the battery > put it back
the thread starter said that no display on the screen brother..
the problem of your mobile is on the hardware side on the ic so to speak
better bring to service center for repair
hook wrote:the thread starter said that no display on the screen brother..
I see. 😊
