When I connect my N95 8GB to PC Suite the sync function doesn't allow me to synce the phone. The button is there but it's "greyed" and therefore non functioning.
I can back up etc. but not synchronise.
Also how do I amend the settings so that I have the option of auto sync when I connect the phone or manual sync. ?
I re-installed PC Suite yesterday and it worked fine for an auto sync but today is back to it's old non sync tricks.
Cheers
CJ
Hi Crapjokes,
Could you please explain your details more? What is your system, which version of PC Suite you are using? :con?
Your system Info XP/Vista?Win 2000?
Nokia PC SUite/NSEries PC suite ?
Version of your PC Suite?
Thanks in advance
cricfancy wrote:Hi Crapjokes,Could you please explain your details more? What is your system, which version of PC Suite you are using? :con?
Thanks in advance
Hi Cric
Synchronise says not connected, but my phone is shown in the drag & drop bit. It also doesn't allow me to add a phone, when I click on that bit in the synchronise folder nothing happens and the Synchronise Now box is in "faded mode"
XP home edition SP2
Normal PC Suite 6.85.14.1
Thanks !
CJ
