Using the N95 as a remote control for the PC?
7 replies · 7,542 views · Started 21 February 2008
I have used most of my Sony Ericsson phones in the past as a remote control in media players, the desktop etc.
Is this possible with the Nokia N95?
rottie wrote:yes it is 😊
How very helpful of you, well done!
I think the op want a little bit more than just an affirmative. Could you not share how it was possible to achive the request?
Pfft!
sicjoke wrote:How very helpful of you, well done!
Pfft!
Are you underpants a bit too tight?😉
Chill out, can't you see a smiley?🙄
1) If the applications you were using on your SE were Java they will also work on N95
2) Try to google for apps:
Bluetooth Remote Control - definitely works
Psiloc Vireless Presenter
PuppetMaster GPRS BlueTooth Remote Control - control your PC using GPRS
3) Also AFAIR if you can be bothered to set it up, uP'n'P lets you control playback on your pc as well.
rottie wrote:Are you underpants a bit too tight?😉
I am using Bluetooth Remote Control. Thank you 😊
King Mustard wrote:I've given that a go and it's fantastic!
OK this looks good but I can't get it to connect via WiFi. ANy tips on how I get the N95 to recognise my home network? It's ok by BT but trying by WiFi I can't get any further than the initial menu, clicking connect results in nothing happening.
