To All
Has anybody tried a 4gb memory card in the 6120c?
I have not got one to try and already have a 2gb which I have filled up.
To All
I don�t, but... already read that it support bigger cards. Try before buy!
nj7
Thanks for the response but where can I find the articles you mention?
The only 4GB card i can find is the new HD cards, will this type fit the 6120c?
Thanks Again
It�s not an article, was across forums... I don�t remember where:frown:
But, try before buy, because on Nokia site, here, http://europe.nokia.com/A4399011, does not mention support for micro SDHC cards, only micro SD... If it�s the case, it reach the limit with 2Gb cards.
To All
Tried a 4gb card and it worked!
Ordered a 8gb and guess what it worked!
So much for it only being able to take a max of 2gb.
Vim1965 wrote:To All
2GB is the official limit for SD cards. Were your cards SD, or SD-HC?
It may be that newer firmwares have added SD-HC capability.
My 6120c with the old firmware version 3.70 had no problems whatsoever with my 8 GB microSDHC card.
The reason why Nokia wrote a 2 GB limit in their specs is that back then there were no 4, 6 or 8 GB cards yet. Nokia couldn't test them and just played it safe.
bad is:
slowly perfomance, battery time is shorter...
but it can be used, if you want more space ;]
Yes I have a new micro 4GB SDHC card that works with my 6120c.
It is a SanDisk 4GB microSDHC.
8g card works dandy in my 6120c. Got rid of my mp3 player now that this phone does just about everything.
