(general feature not supported)E51!
9 replies · 14,361 views · Started 21 February 2008
ة:con?(general feature not supported)it`s the message appear when i try to use camera on nokia e51!!!
i cant use for video or photo!!any idea?
thank u in advance
Format the phone... type *#7370#. It lost all stuff inside:icon4:, so do a backup first.
prince01 wrote:ة:con?(general feature not supported)it`s the message appear when i try to use camera on nokia e51!!!
thank u in advance
Take it to a Nokia Service Centre.
nj7 wrote:Format the phone... type *#7370#. It lost all stuff inside:icon4:, so do a backup first.
I've format the phone but it still aper this"Feature Not Supported".I have a 2 GB card memory...i try without card to format the phone...but nothing.So with the card plugged😞
A lot of thanks!!!
senior_cor73z wrote:I've format the phone but it still aper this"Feature Not Supported".I have a 2 GB card memory...i try without card to format the phone...but nothing.So with the card plugged😞
A lot of thanks!!!
Format also the card! Or try using another card.
nj7 wrote:Format also the card! Or try using another card.
I've format the card too but the same problem....i change the card but the problem persist....i'm disperate😮:con?....i tried to use the phone without card but nothing
it is possible to can't repair the phone?
Thanks😊
I've had the same problem. i just removed the battery and the SIM card put it back. after that it's working fine 😊
When i click on the camera, an error message appears say camera feature not supported. it`s the message appear when i try to use the camera on nokia N81 2GB
In Addition, all the memory card data is lost weekly such as messages, pictures, themes and i have to restore an old backup. i tried to install the software updater but nothing changed the message still appears when i click on the camera button. i can't use the camera!!any idea? 😡
Thank u in advance
