Small problem N80.
5 replies · 4,670 views · Started 22 February 2008
I'm not sure what I did, but now if I take a picture the camera doesn't play a sound anymore. I tried all the camera tones none of them works. Did I turn it off somewhere?
Another questions is, is there anyway to change the shortcut button for when your on a call. I want the right button to be mute rather then loudspeaker, how do I change that? Or should I say can I change it?
For the click sound, check if the phone is on silent mode...
You can´t assign new location to the menu.
You can�t assign new location to the menu.
It wasn't on silent mode.
The click just misteriously stopped working after I switched through all 4 to see what they sound like.
You can always do a soft reset... but it�s a lot of work because a little thing:frown:
How do I do a software reset? Can you link me or walk me through it? There are other small glitches on my phone. Maybe a reset will help.
