Does anyone know if it is possible to increase the keyboard repeat rate for the E90?
Tnx
Tnx
As far as I know, not.
nj7 wrote:As far as I know, not.
Hmm. found this one : http://discussion.forum.nokia.com/forum//forum/thread/113038/ that seems to indicate that there is a method for it but I am not sure whether that applies for a given app context or the entire OS/UI.
Am I the only one thinking that the E90's repeat rate would be great to adjust 😉 ?
hey jazz, can u unsign nokmote
jazzmadrazz wrote:Hmm. found this one : http://discussion.forum.nokia.com/forum//forum/thread/113038/ that seems to indicate that there is a method for it but I am not sure whether that applies for a given app context or the entire OS/UI.Am I the only one thinking that the E90's repeat rate would be great to adjust 😉 ?
Even so, seems a little experimental. Maybe there is some sort of software for that, but I don�t know:frown:
