HowardChui 3650 feature.
5 replies · 2,871 views · Started 30 January 2003
Howard Chui has done a good detailed feature on a pre-release 3650. I think he likes it but has not posted a conclusion about the device yet (Probably waiting for the final release).
Anyway here's the link
The Howard forums are a good North American (Howard is based in Toronto) phone site. They are also prepared to give Symbian a fair hearing which makes a change for sites on that side of the pond. They even have a dedicated P800 forum as well as a general Nokia one that has quite a lot of 3650 coverage.
Don't worry I still think AAS is the best 😃
Howard Chui's review shows a 3650 that has a calendar. Here in Sweden Nokia says that there will be no built-in calendar, it has to be installed as any other 'extra' application. Does someone know if that really is the case? Sounds strange to me.
Indeed it does! As long as it is a screenshot from a software version that will be used in Sweden that is 😉
i can't tell you anythyng about swedish version but don't think that will throw out the calendar. it would be stupid of them to do that , and what's the use of not installing it
I completly agree with you! When I first heard that it wouldn't have a calendar I thought 'What?!? No calendar, when the 7650 has that?' After all they have very similiar firmware sharing the same OS etc meaning the calendar already has been done for the 7650.
