Gallery and Deleting MMS
2 replies · 2,043 views · Started 24 February 2008
I've got a couple of questions. I've upgraded from an N95 to N95 8Gb and found a couple of problems I was hoping someone can help with:
1) When I get sent a picture message I can't delete it after I have viewed it without turning my phone off and on again.
2) The gallery was picking up image files from my Garmin install so I used Y-Browser to hide the folder they were in. In the gallery I still have a list of the images, but they're now red crosses. Is there some sort of index file to delete that will reset the gallery?
8Ball
1. Have you deleted the recieved message before trying to delete it? Maybe its attached to that somewhere?
2. I cant say its the same but the N80 when I did similar needed a reboot?
There is. In Ybrowser, look in the folder where the images are that you hid and you will see a folder called _pAlbtn. That holds thumnails created by the gallery, so delete it.
A reboot might do this for you anyway though
