Reanimate E51 - Hard Reset
5 replies · 66,521 views · Started 26 February 2008
Hi Folx,
if the phone tells u: startup failed, please contact your dealer use this method to reset:
while phone is switched off, press * and 3 and green button, keep pressed, switch on the phone an wait for the PIN to enter
works also on other symbian devices by Nokia, eg. n93.
well, that doesn't work for me 😡
I switched my e51 off this morning, then later i wanted to turn it on, and i only got a small vibration (like normal), the backlight goes on, and after a few seconds it's turned off! ARGH
Hard reset doesn't seems to work, any other suggestion, or i just have to go back to t-mobile?
i have same issue. but my bat is fully charged, all i get is a white screen for a min and it turns off :frown:
my e51 is having the same problem...i showed in 2 nokia care's but for no use..they said that it can't b repaired now..i am so sad without my e51...😞
