I recently updated my firmware and I no longer have the option to play songs in a random order!
Anyone have any ideas to help me?
Which firmware did you update to?
4.0747.31.0.1
Odd that Nokia would break something so fundamental. Still you could perhaps just try another music player (e.g. OggPlay).
Yes it is =/ I dont like the look of OggPlay anyone else have any suggestions for a good player?
"I dont like the look of OggPlay "
You mean the actual physical appearance? There are different skins available you know. Or do you mean there's something else about it you don't like?
Ignore my last post xD
I have now fixed the problem! What you need to do is:
1) Open the music player
2) Select Artists
3) Select the Bands name
4) Play one of the songs
5) Choose 'options'
6) Shuffle 'on'
7) Close the music player
Very long way to do it but it works and makes all playlists play in a random order 😃
