garmin mobile xt speed settings
4 replies · 4,392 views · Started 27 February 2008
is there a way to change the settings because the other day i was driving along and it wouldnt shut up saying its a 25mph zone but it was a 40??? i know you can turn the alerts off but thats not what i want. please help. been all over the garmin site, emailed them and still nothing.
There is no way to correct this within Mobile XT itself, the best solution would be to contact Garmin (or whoever built the POI or map file) and discuss it with them. The alternate is that you just edit the file yourself using MapEdit or similar and up the limit to whatever it should be.
I do this quite often for where I live, the road workers and police are forever changing traffic flow. Fortunately we have no (enforced) speed limits in this country so this particular issue is not a major problem for me 😊 Speed limits are still nice to know though.
dchky wrote:There is no way to correct this within Mobile XT itself, the best solution would be to contact Garmin (or whoever built the POI or map file) and discuss it with them. The alternate is that you just edit the file yourself using MapEdit or similar and up the limit to whatever it should be.
Woopie for once I can give an answer 😊, only cause I had this problem and sent a snoty to the people who I got the POI's from SCBD :redface: . Seem cheap and so far so good.... First Class custermer care 😉
You have to make sure you have your POI's entered in MPH not KPH when you up load your POI's in the POI Loader.
Also if you go to manual you can set the range the alarms go of at... Just incase you are slightly absent minded when passing one of the 15:icon4:, yes 15 speed cameras :frown: you pass on the way to work...
Gerrit
