Can it connect to a BT GPS unit and BT headset at the same time?
Thanks for any info. 😊
Yes, it can I do it all the time while driving.
DaJ
Cheers. 😊
but please take into consider that if you use more than one bt connection at the same time, bt bandwith will be shared between the connections.
