Rock n' Scroll
6 replies · 3,816 views · Started 29 February 2008
Is anyone playing with this yet?
I still havent got mine working, am just removing other accelerometer based apps which is annoying!
Well, having had a quick play with it, it seems like Samir has some major competition from this tidy little app.
It has two modes of operation:
'Flick' mode will only move the cursor when you flick the phone in a certain direction, this means you can hold it at a natural angle and it will still work
'Game' mode makes it work like Nokmote where it is neutral when the phone is flat and any tilting will move the cursor.
It has push and pull support so flicking the phone away from you (pushing it 'down'😉 selects and pulling it towards you goes back up a level in the menu.
Also, it has screen rotation (like rotateme) built in!
For a beta, this is a very very promising app. Hopefully the next version will have some adjustable sensitvity settings
none of what these provide seem to be able to increase your speed over key pressing?? Is that the case here?
In My Opinion I think that manual menu navigation is quicker, especially with a program like SkyQuiKey. However, I must admit that the most impressive thing about this program is the autorotate/scroll function. If you have a long page you are reading you can rotate it into landscape mode then just tilt it for an automatic scroll down the page. I've been waiting for an app like that for a while now. If you could disable the "menu navigation" in portrait mode, and only have it rotate and scroll, then THAT would be a good app.
Of course my opinion and $1.50 will get you a cup of coffee.
-Zumstin
