OxyCube debuts
2 replies · 2,459 views · Started 29 February 2008
Oxygen Software have been plugging away at their Phone Manager product for years, and they've just announced a major revamp, rebrand and relaunch. OxyCube is released yesterday and is compatible with a wide range of handsets and provides syncing and file browsing functions. (via SymbianOne)
If you have Sony Ericsson Suite you should disable all connection types there and in m-Router.
What connection type do you use?
Have you installed OxyAgent-UIQ2 in your phone? Without this application ther will be no connection. You can find it in Program files/Oxygen Software/SymbianOPM/Agent folder on your PC.
