N73 ME and Windows Media Player 11
5 replies · 9,070 views · Started 29 February 2008
I am currently unable to get my N73 ME to connect with Windows Media Player 11. I have only been able to find a driver for WMP 10.
Does the N73 work with WMP 11? Can anyone suggest how I can go about getting connected? Thanks. 😊
I´m not sure about what´s your problem, but do you already try PCSuite?
U can Use the Nseries PC suit version 2 and that can be downloaded from nseries support site it works with WM11
Hi bootsbradford,
I hope while connecting your phone with USB, you are selecting Media player option i guess right? It has to be selected as Media player mode only to connect with Media Player option
Hi bootsbradford,
I also have N73 , to synchronise your n73 with windows media player 11, there is no driver available, but only one version of nokia pc suite works with windows media player which is 6.82.22.When you'll connect to your pc via bluetooth or USB, just open up windows media player 11, go to library,it will ask you to setup your mobile for sync.Thats it!Your done.
