i recently bought a new 8gb micro sdhc. How do i transfer my old apps and the rest of the contents from my old micro to the new one ? do i just copy and paste ?Will everything work as it should ?
n82-how to transfer apps from old card to new 8gb card?
I know this is an old thread but I have just ordered an N82 and a new 8GB micro SD card and I was wondering the same.
Can I just copy the supplied memory card to my pc using a card reader and then copy this to my new 8GB card? Would everything work OK if I did that?
Thanks for any advice.
If you copy also all the hidden/system files and file attributes, then most things should be all right.
Some applications might not run properly after this, though, and those you'd have to reinstall.
Just use a PC card reader, and copy everything, including hidden/system files.
As an added safety measure I would recommend formatting the card with the same volume name as the original.
Power off the handset before you remove the old card and insert the replacement card before powering back on.
This way your N82 should not even detect you have changed the memory card.
