EMAME9210
16 replies · 3,506 views · Started 31 January 2003
please... emame9210 is a port of emame to the communicator.
go to www.mame.dk for more info.
I will!!!, it seems there are games like Mortal Kombat and stuff available for the mame thing... Damn I hope this thing can handle those game listed on www.mame.dk, I actualy ignored this "mame" thing because of the stupid lame name ... *g*
So far 1942 runs great, (get exe 3 driver package)
But the game I want the most (Ironman Offroad) won't run because it need more memory .. very very very depressing ...
BTW 1942 works, but on the edge of being to slow ...
how did you make it work?
did u copy the zip file to to the rom folders?
i chose to install emame9210all...
me 2 ...
so what I did, I got the 1942.zip in emame\roms\
Then started the emame set 3 exe in emame\
Chose 1942 and away we go 😊
Got some other games working 2, but nothing fancy, will continue searching but in the meanwhile all my time is going to MGS Karting 😊
yup.
u can find roms at www.mame.dk,
copy the roms (do not unzip) to EMame\roms the rom version should be for V0.37b7...
happy hunting... 😊
Well, I might be tired, or I am not so good to new stuff... :cry:
Can you guys write a short tutorial?
Monday all the 9210 users will cry of joy if this works on 92x0.
Cheers.
ok...
download the EMame9210All.sis file at http://koti.mbnet.fi/~haviital/
install the file to yout phone...
Upon installation (I installed the file to the MMC) a Memory card\EMame folder has been created. Use the exe file to launch the games, EMame9210Set1.exe up to set 4... Each set has different drivers so be sure to check out the driver list at http://koti.mbnet.fi/~haviital/
finally you need the roms for the games so you can play them... you can download the roms at www.mame.dk
example: assuming you want to play 1942, the game driver can be found at EMame9210Set3.exe and you can download the rom file at www.mame.dk the file is aptly named 1942.zip copy this to Memory card\EMame\roms (note: do not unzip) now you can play the game...
Just run EMame9210Set3.exe scroll down to 1942 then press enter.
1942 has been tested already and although a bit slow I still had a great time playing it... I'll post games that I've tested here... please post them here also... 😃
Hi there
Can get pacman working fine, but am struggling with slapfight and galaga, get Application Closed box, with KERN-EXEC Reason code, number 3, is this lack of memory?3204kB free on mem card?
Got Slapfight working, was a lack of memory, thanks aj96.
I got Xevious working too, I love these games, just wish they had sound, would be nice to play them vertically too 😮
