I was just wondering if the BST-33 at 1200 mAh would make a difference in battery life if so, then by how much? Also, I was wondering if it would make a difference in reception.
Here's the battery:
Thanks,
l2ULEJJ
Here's the battery:
Thanks,
l2ULEJJ
What ever battery you put in, it wouldnt affect the reception.
But I would suggest you stick with OEM products. You don't want to spoil a perfectly good phone now, do you?
It would really be a disappointment for all that pre-ordered the P990i to receive a BST-33 instead of the 34, so I hope SE will come up with some sort of refund or change promotion once the 34 is readily available.
