Problems with MumSms
4 replies · 5,585 views · Started 03 March 2008
Hi dudes,
this is my first post here!!!
recently I have installed the mumSms 4.16 and configured a password,then changed it but forgot.
in order, have uninstall to get my sms free from MumSms because it was blocking them,but ti is still blocking my sms even without the app installed.
tried with X-plorer to find on C: and Memory Card if there's some file which was not removed during the uninstall and didn't find nothing.
can someone help me on it???
what should I do to get my sms free from this f*** app???
please need it urgently because it is blocking a lot of important message...
thanks in advance...
sorry for my poor english!!!:tongue:
Wirelessly posted (Nokia N72: Mozilla/4.0 (compatible; MSIE 6.0; Symbian OS; Nokia N70/5.0706.4.0.1; 9399) Opera 8.65 [en])
Have you really "uninstalled" it or just deleted through X-plore? Try reinstall and then uninstall..Now it should not block new messages...(your old hidden messages will be there even if you uninstall app.,and it can be recovered if you remember your password in future).
Messages are stored in system>mail folder..There are 2 parts (1)index file in system>mail folder (2)message proper in system>mail>various subfolders...MumSMS changes entry in "index" file so you don't see msg even if it exist there...
If you have really important msg than you see it by following crude method(using X-plore)::😞1) change setting sort by to "date" in xplore(2)goto system>mail>(00001001_S) or similar folder then search for file *.* so you will get full list of files sorted by date,each file is a seperate message.(3)now you can use inbuilt hex viewer to see the message...... 😊 all the best
djnanuatwork wrote:Hi dudes,
Doesn't matter you just download Smart Guard or Smart Hider. That software will show all your hidden msgs. I have already used both of them in 6670 now I have E51 didn't get mumsms for E51. If you have can you upload here? And don't forget none of the above method will help you.
