I get the above error message while trying to update my N95 to the latest sofrware.... tried re-installing from Nokia on the NSU but still comes up... any ideas?
"Missing critical Software" error
try uninstalling it, and properly deleting the Nokia dir from program files... then re-install. Also, you need to check you arent blocking any download with antiv/firewall and you restart,.
