When you unlock/change firmware?
1 replies · 1,271 views · Started 06 March 2008
Do you lose all your current apps and videos/music that you've put on the phone?
How long does it take to change firmware?
anth619 wrote:Do you lose all your current apps and videos/music that you've put on the phone?
apps almost certainly .. you'll need to re-install them
music/videos etc almost certainly NOT - you probably have them saved on the Card .. however if you have an N95-8G you should back this stuff up.
I strongly recommend backing up everything before you do your upgrade!
I takes about 20-30Minutes .. to do an update .. depending on the speed of your connection. That doesn't include the backup or the restoration of any data.
Good Luck!😊
