Hi all,
i have had my e90 for over a month now and have noticed
the sound volume on the normal ear speaker is
going down has this happened to any1 else ??
is there a code i could put in to louden it ?
the volume control is on its max and the loud speaker is
as loud as it was when i first had it
e90
v7.40.1.2
03-10-2007
ra-6
nokia e90 213.03
That sounds very strange and one I think I'd get checked at an NSC, TBH. I haven't heard (no pun intended!) of this before so it could be a unit fault. I take you've tried the usual round of hard and soft resets and also let NSU reflash it (even if it's with the same version)?
Tim
hi
i was going to wait till new version came out b4 flashing it
but then last night the phone went down anyway it overheated
i turned it off took battery out left it for a while then put battery back in n it
just overheated again n when turned on it didnt even show the nokia logo
anyway i took it to a nokia repair centre n they r sending it away they say it
could taker up to 2weeks 😞
