Infrared Remote Control with P1i
5 replies · 23,842 views · Started 08 March 2008
Hi there
I would like to Use my p1i as an infrared remote control. I have googled, but as far as I see there is no such program for the p1i, psiloc for instance does not support the p1i.
Do u know any other apps that work with the p1i?
Greez
swisselite
.. how come? I guess many people are looking for it..
will there such a prog ever and it is just a matter of time or will there never be such a prog?
SwissElite wrote:.. how come? I guess many people are looking for it..
your guess is as good as mine lol!
The UIQ3 OS has limitations about the use of the IR port. Ther is no way until now, of making software to use the IR port as IR remote.
HI,
Yes, i know the other apps. This is the site where you can find all the details www(dot)flyinghippy(dot)co(dot)uk
