Downloaded this music video in .mkv format. Bluetoothed it to my phone and it won't play. I was sure it wouldn't but gave it a try. How can I play it thou ? What would I need to convert it into and what should I use ?
Thanks a bunch !
Thanks a bunch !
Google is your friend 😊
lovesign wrote:Google is your friend 😊
I thought this forum was 😉 Thanks 😊 Those are Windows apps, I'm on a Mac.
You can always buy CorePlayer, which will play mkv files (as well as 239849038483 other formats) on your phone.
The first result of my google search brought up this thread in a mac forum. Is this of any use?
zxon wrote:The first result of my google search brought up this thread in a mac forum. Is this of any use?
Going through the thread now. Thanks a lot :icon14:
Visualhub (or the free version; iSquint) will do the job perfectly - it's what I use on my Mac. 😊
vlc plays mkv files on windows i think theres a mac version
Super will convert matroska files. I use it myself.
