Hey people, new here, so hi 😛
Ive got the unlimited web bolt on with 02, but im wondering if anyone knows which option i choose so the data is transferred using my bolt on and doesnt charge me any more? For example where it has the options to search for WLAN, select WLAN, or it has 02mobileweb or 02active etc, whch do i choose?
Thanks in advance, and sorry if that didnt make much sense, running low on sleep 😮
the WLAN connection does not effect or have anything to do with o2 thats for conecting to a wireless network. You should be able to use any of your o2 settings. the bolt on doesnt have a seperate setting it will still be active when any data is being transfered
Yeah i know the wlan has nothing to do with 02, was just using that as an example of which menu i was looking at lol
Thanks for the advice, i thought hter might have been different options to connect (via 02) for a reason, just wanted to clarifiy before i started using it.
Thanks for the confirmation =)
